Hi @AM_10747981
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hi @Catalina
Hi @AM_10747981,
Thanks for confirming!
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
When you say "synchronize" what do you mean exactly? See https://www.ptc.com/en/support/article/CS251941 for difference between Synchronize, Update, and other similar terms.
Per the Help, Synchronize gets triggered automatically by several different things: https://support.ptc.com/help/windchill/r12.1.2.0/en/#page/Windchill_Help_Center/ProEWCInteg/ProEWCIntegGWCacheRefresh.html#wwID0EUYLT. You can use Tools > Synchronize to synchronize manually at any point. Also, that same help article says there's a preference to control the automated synchronize timing: "Workspace > Access rights refresh interval, allows you to set the interval for how often a comprehensive workspace refresh is performed (default minimum value is 1800 seconds) "
Hi AM_10747981,
It s achievable using custom code
