Is it possible to auto synchronize from any custom commonspace action trough windchill API
AM_10747981
2-Explorer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.25
Is it possible to auto synchronize to workspace from any custom commonspace action trough windchill API ?
Workspace synchronization by commonspace actions must be automatic
5 REPLIES 5
Hi @AM_10747981
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Are you referring to synchronizing CAD documents or all types of objects from Commonspace to Workspace?
  • Will this apply to a single user’s workspace or multiple workspaces across different users?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Hi @Catalina
  • Yes I am referring to synchronizing CAD documents
  • And this should apply to a single user’s workspace.
Hi @AM_10747981,
Thanks for confirming!
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
When you say "synchronize" what do you mean exactly? See https://www.ptc.com/en/support/article/CS251941 for difference between Synchronize, Update, and other similar terms.
Per the Help, Synchronize gets triggered automatically by several different things: https://support.ptc.com/help/windchill/r12.1.2.0/en/#page/Windchill_Help_Center/ProEWCInteg/ProEWCIntegGWCacheRefresh.html#wwID0EUYLT. You can use Tools > Synchronize to synchronize manually at any point. Also, that same help article says there's a preference to control the automated synchronize timing: "Workspace > Access rights refresh interval, allows you to set the interval for how often a comprehensive workspace refresh is performed (default minimum value is 1800 seconds) "
MTH
(To:AM_10747981)
Hi AM_10747981,
It s achievable using custom code
