Is it possible to clear Float data type attribute in windchill?
BA_10670508
6-Contributor
Hi All,
I want to clear attribute for specific use case is it possible to set Empty value for floating point or Long data type in windchill.
Is it possible to set the attribute value as Empty for FloatingPoint data type.
Basheer
If you are asking if you can set the value to "Empty". The answer to that is no.
If you’re asking, can you delete existing value the answer is yes. This can be done without iterating (checkout/checkin) the object as well.
