Is it possible to download file/document from Windchill using REST API
skuppamohanram
11-Garnet
Is it possible to download file/document from Windchill using REST API? If you have some example, please share it here.
Thanks.
8 REPLIES 8
afaik, windchill does not support REST
Windchill does support some OOTB REST Services.  You will find the documentation in Windchill.
With 11.0M010 you are not able to add some own REST services but this should come with 11.0M020 or later.
The Documentation also has the ability to test the services. So have a look there.
Hi Saravanan,
Currently, I dont think we have Rest API's available for content download.
Bhushan
Hi Bhushan,
Thanks for reply. Can we customize to add our own functionality?
You can download the viewables with the OOTB REST service e.g. for a WTDocument
Hi  Ruegg,
Thanks for your reply. We can download it WTDocument content.
Can we customize REST to add our custom functionality? I hope it is possible.
There is not OOTB possibility to extend the Rest services at the moment. PTC told me that this should come with 11.0M020 or 11.0M030.
Thanks Ruegg...
