Is there a way to add another workflow the list of workflows in the right click new menu?
EdSiekman
6-Contributor
I am wanting to add a custom workflow to the right click new menu.  Is there any way to that?  Thanks in advance!
2 REPLIES 2
Please have a look at following case:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS185927
  • To add a custom create action for Change Request soft type to folder Action > New sub menu
    • Create a subtype of Change Request
User-added image
  • Copy the action model folderbrowser_toolbar_new_submenu from <WT_HOME>/codebase/config/actions/FolderManagement-actionModels.xml to <WT_HOME>/codebase/config/actions/custom-actionModels.xml
  • Add the below line to the above copied model in custom-actionModels.xml<action   name="create"  type="AgendaCR" resourceBundle="ext.custom.ActionDefinitionsRB" />   <!-- New Agenda Type Change Request -->
  • In <WT_HOME>/codebase/config/actions/custom-actions.xml file added new object type for the subtype of Change Request.
<objecttype name="AgendaCR" class="wt.change2.WTChangeRequest2|com.ptc.ptcnet.AgendaCR" resourceBundle="ext.BWIR.ActionDefinitionsRB">
  • Create an resource bundle file to localize the created action
  • For example create ActionDefinitionsRB.java under WTHOME/src/ext/custom​
package ext.custom;
import wt.util.resource.*;
@RBUUID("ext.custom.ActionDefinitionsRB")
public final class ActionDefinitionsRB extends WTListResourceBundle {
    @RBEntry("New Agenda Change Request")
     public static final String PRIVATE_CONSTANT_1 = "AgendaCR.create.description";
    @RBEntry("NEW_ICON.gif") // <WT_HOME>/codebase/netmarkets/images
    public static final String PRIVATE_CONSTANT_2 = "AgendaCR.create.icon";
  • Compile using the below command:
ant -f bin/tools.xml class -Dclass.includes=ext/custom/ActionDefinitionsRB.java
  • Make sure ActionDefinitionsRB.class is generated under <WT_HOME>/codebase/ext/custom
  • Stop Windchill Method Server
  • Clear Tomcat and Info*Engine cache
  • Restart Windchill Method Server
  • The new action should now be under to Action -> New menu as below
User-added image
  • Note: the image size must be smaller than 16*16 pixel and it should be placed inside <WT_HOME>/codebase/netmarkets/images directory.
  • Disclaimer : PTC recommends following best customization practices to avoid maintenance installation process overwrite. Please go through “5. Managing Customizations” chapter in Windchill Customization Guide.
Thanks for the reply Bjorn.  Really appreciate and looks like just what I am looking for but have not yet had a chance to try.  thanks again!
