Is there any listener event to listen when WTDocumentUsageLink is created
SB_10904295
11-Garnet
Is there any listener event to listen when WTDocumentUsageLink is created.
Fadel
23-Emerald I
(To:SB_10904295)
Hi @SB_10904295
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  1. Are you looking for a system event listener or planning to implement a custom Java listener?
  2. Is the goal to trigger logic immediately after a WTDocumentUsageLink is created?
  3. Is this needed for all link creations or only under specific conditions (e.g., document type or context)?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Worse case there is a pre and post store event that you can use to pick up on this. You would need to filter for this class.
Fadel
23-Emerald I
(To:SB_10904295)
Hi @SB_10904295,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC
