Listener for HDIC Conversion
CG_10277515
Version: Windchill 12.1
Use Case: We need to create attribute in which we need to store value if Source have update to date image or not . For storing value , we need trigger point . We need event which listens when HDIC conversion takes place from CATIA to creo.
Description:
Hi @CG_10277515,
Thank you for your question.
Vivek N
Community Moderation Team.
tarik_p
(To:CG_10277515)
Generally speaking, when an event takes place and we don't know its name, we enable events verbosity loggers, see Article - CS43313 - How to determine which event to listen for in Windchill (ptc.com).
Once done, we can implement the business logic by listening to this event, note that not all events are supported: see Article - CS361423 - [Knowledge Hub] Windchill PLM - Events and Listeners (ptc.com).
+Bonus: Whenever you would like to know more about a general functionality, search for its hub on the knowledge base, you will get more information!
