I have a Little excel database, and I would like to read the "Status" and the "Version+Iteration" of drawing.
Also the description, maintaining some kind of Read-Only link from Windchill, I suppose that somethiing like DTI "DEsktop integration" that do an OOTB from office applications, but is possible to do ?
@Marco_Tosin shared link if for the document itself ( not data inside ) right ?
IMO Desktop integration cannot do that.
@mbuonfiglioli you need to make a report
Report can be exploited directly or linked as data source in excel.
In these TS articles you can find some advice to work with DTI.
How to add custom attributes to Desktop Integration (DTI)
https://www.ptc.com/en/support/article?n=CS36657
Best practices and recommendations for inserting and updating attributes in MS Word using DTI
https://www.ptc.com/it/support/article?n=CS194304
Does "Windchill Desktop Integration" support multi value attribute?
https://www.ptc.com/en/support/article?n=CS67201
Here some link to help center:
https://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=DTIMapPropertiesAbout&action=show
https://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=DTIWCDocAttributesInsert&action=show
Be very careful and pay attention to this article:
Windchill attribute mapped to Microsoft Word through Desktop Integration does not show the correct value when downloaded without DTI
https://www.ptc.com/en/support/article?n=CS223475
Hi Vincent,
yes, as you wrote, DTI cannot make a list like the image from Excel file.
You could link attribute from a Windchill WTDocument and put it in his Primary Content, using DTI.
To obtain something like in Excel image you have to use a query builder report as source.
Here you can find lots of report ready to use and some useful advises on how to work with query builder.
