Little database, to "Read only" data from WINDCHILL.
mbuonfiglioli
I have a Little excel database, and I would like to read the "Status" and the "Version+Iteration" of drawing.Little Database
Also the description, maintaining some kind of Read-Only link from Windchill, I suppose that somethiing like DTI "DEsktop integration"  that do an OOTB from office applications, but is possible to do ?
@Marco_Tosin shared link if for the document itself ( not data inside ) right ?
IMO Desktop integration cannot do that.
@mbuonfiglioli you need to make a report
Report can be exploited directly or linked as data source in excel.
4 REPLIES 4
In these TS articles you can find some advice to work with DTI.
How to add custom attributes to Desktop Integration (DTI)
https://www.ptc.com/en/support/article?n=CS36657
Best practices and recommendations for inserting and updating attributes in MS Word using DTI
https://www.ptc.com/it/support/article?n=CS194304
Does "Windchill Desktop Integration" support multi value attribute?
https://www.ptc.com/en/support/article?n=CS67201
Here some link to help center:
https://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=DTIMapPropertiesAbout&action=show
https://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=DTIWCDocAttributesInsert&action=show
Be very careful and pay attention to this article:
Windchill attribute mapped to Microsoft Word through Desktop Integration does not show the correct value when downloaded without DTI
https://www.ptc.com/en/support/article?n=CS223475
Marco
Vincent-Kulak
this is what I was looking for, thanks a lot
Hi Vincent,
yes, as you wrote, DTI cannot make a list like the image from Excel file.
You could link attribute from a Windchill WTDocument and put it in his Primary Content, using DTI.
To obtain something like in Excel image you have to use a query builder report as source.
@mbuonfiglioli
Here you can find lots of report ready to use and some useful advises on how to work with query builder.
Marco
