Looking for a Part Where Used for current Version only
lgrant
I'm looking to add a Where Used report that only returns items if the parent part is the current version.
WC 11, M020
I see there is some help here but report creating is not in my wheelhouse 🙂
https://community.ptc.com/t5/Windchill-Questions/Resource-for-reporting/m-p/448738
Attached is a version of the report but for EPM Docu's
8 REPLIES 8
Vincent-Kulak
(To:lgrant)
Hi
If you mean latest version when you say "current version", i have attached an exemple edited from CS210416
lgrant
(To:Vincent-Kulak)
Not quite. It seems to return where it is structured (I would need to at the Version into the report table to see). If I revise an assembly and drop the part I am searching for it still shows in the report.
In Vincent's xml file there is not a sub-select, that is the only way to achieve the very latest version.
Marco
lgrant
(To:Marco_Tosin)
Not my skill set. Anyone know how to do that?
Vincent-Kulak
(To:lgrant)
Exemple in CS1171
Attached updated version
lgrant
(To:Vincent-Kulak)
Thanks Vincent. Having trouble loading it.
We are on 11, M020
Vincent-Kulak
(To:lgrant)
I have re-exported as zip ( 11 M030 )
lgrant
(To:Vincent-Kulak)
Thanks.
