I have an attribute loaded for the WTChangeActivity2, and I want to map the attribute for the associated resulting objects of that change activity using Alias attribute concept. Please let me know the feasibility of doing the same.
Thanks in advance.
Sha
Can you try
theChangeable2@wt.change2.ChangeRecord2~theChangeActivity2^wt.change2.WTChangeActivity2~<CA_IBA>
Hi @Fadel
Have you faced a similar requirement? https://community.ptc.com/t5/Windchill/Alias-attribute-between-Change-Objects/m-p/923558
