Need to implement validation on submission of rename if new name is already present
TP_10729144
Version: Windchill 13.0
Use Case: Trying to implement validation on submission of rename wizard if name is already present
Description:
Trying to implement validation on submission of rename wizard if name is already present but not working
6 REPLIES 6
Fadel
23-Emerald I
(To:TP_10729144)
HelesicPetr
(To:TP_10729144)
Hi @TP_10729144
Do you use a wizard ? and Processor that do what you need?
If so use preProcess method to check if the name already exists in the system and return an error.
@Override
public FormResult preProcess(NmCommandBean nmCommandBean, List<ObjectBean> objectBeans) throws WTException
	FormResult formResult = super.preProcess(nmCommandBean,objectBeans);
	formResult.setStatus(FormProcessingStatus.FAILURE);
	return formResult;
PetrH
Hi There is no form processor implementation for rename and there is  no wizard page  to handle ok button validation
HelesicPetr
(To:TP_10729144)
Hi @TP_10729144
So you need to write some js script that do what you need.
PetrH
yes  thinking for script or processor implementation but where exactly do i need to implement as I said there is no wizard or proccessor
HelesicPetr
(To:TP_10729144)
Hi @TP_10729144
I guess that you are talking about rename wizard, so you need to find the rename table and try to set a JavaScript for the name filed if it changes run a js script that will check all fields on the page an throw alert if there is same name....
PetrH
