Number of files in the Attachments table
smcvr
Hi Community,
I need to check the Attachments table on launched streams.
How can I find out how many files are in the table from Expression? I will check the number of files that need to be uploaded according to this quantity.
For example, in the task step, the user needs to upload 3 PDFs, but he uploaded only one. How can I prevent that task from closing by having it checked?
avillanueva
22-Sapphire III
(To:smcvr)
This was just my solution. There may be others that are easier but this should allow you to create that hook or place to insert your custom logic. I modified the create and edit jsp wizards for WTDocument to add the following custom step.
<%-- adds attachments to the document --%>
<jca:wizardStep action="attachments_step" type="attachments" />
<%--- Customizations for Electrical Eng Docs --%>
<%-- process if matches drawings as documents --%>
<jca:wizardStep action="process_drw_docs" type="document" />
The action "process_drw_doc" is a reference that I then defined in config/actions/custom-actions.xml:
<objecttype name="document" class="wt.doc.WTDocument" resourceBundle="com.ptc.windchill.enterprise.doc.documentResource">
        <action name="process_drw_docs" preloadWizardPage="false" hidden="true">
            <command class="customization.electrical.DrawingDocumentProcessorDelegate" windowType="no_content"/>
        </action>
   </objecttype>
That "delegate" class is executed but noticed that hidden=true so users never see this step. This is the basic form of that class implementing the postProcess method where you can put your checks.
public class DrawingDocumentProcessorDelegate extends DefaultObjectFormProcessorDelegate {
	 * Delegate uses only postProcess hook to inspect WTDocument. postProcess
	 * will evaluate the type against list in ee.properties.
	 * @param bean NmCommandBean
	 * @param list Object Bean list
	 * @return FormResult
	 * @throws wt.util.WTException
	@Override
	public FormResult postProcess (NmCommandBean bean, List list) throws WTException
		log.debug("entering postProcess");
 You can get the reference to the WTDocument from the list which are ObjectBeans and finding the one that has the WTDocument on it.
	 * returns WTDocument associated with CreateEdit Form. Should only be called from Edit.
	 * @return WTDocument
	private WTDocument getDoc(List list)
		//should be only one document, therefore one object bean
		for (Iterator<ObjectBean> beans=list.iterator();beans.hasNext();)
			ObjectBean objBean=beans.next();
			//if object on bean is a WTDocument, continue
			if ((objBean.getObject() != null)&&(objBean.getObject() instanceof WTDocument))
				return((WTDocument)objBean.getObject());
		log.debug("Could not find WTDocument. Returning null");
		return null; //WTDocument not found in bean.
From there its standard method to inspect attachments. If they violate your rules, return a FormResult that indicates such.
4 REPLIES 4
avillanueva
22-Sapphire III
(To:smcvr)
What kind of object are you checking? I was able to add hidden steps to a WTDocument wizard that can read the uploaded files and in your case, validate that there are 3.  Should be easy enough to have it kick back a WTException which would provide the user a message indicating that 3 files are required.
smcvr
(To:avillanueva)
Hi @avillanueva ,
How can I create a WTDocument wizard that can read uploaded files and verify that there are 3.
avillanueva
22-Sapphire III
(To:smcvr)
        </action>
   </objecttype>
	@Override
smcvr
(To:avillanueva)
Thank you @avillanueva 🙂
