OData - CompleteWorkitem returns the error "This task cannot be updated..."
  • December 12, 2023
  • 3956 views
Dear all,
I have a question regarding completing the work items. I have a work item which includes a custom EnumeratedType attribute "MySize".
When I try to complete the activity using the OOTB Endpoint from Workflow Domain, I am getting an error that the enumerated type is not supported like below:
"This task cannot be updated.Variable type ext.dropdown.MySize is  not supported."
URL: {{baseUrl}}/WorkItems('{{WorkItemId}}')/PTC.Workflow.CompleteWorkitem
Request Body:
    "AutomateFastTrack"false,
    "UserEventList": ["Yes"],
    "VoteAction""",
    "WorkitemComment""Dummy",
     "Variables":[{
        "Name":"MySize",
        "Value":"Small",
        "TypeName":"ext.dropdown.MySize",
        "DisplayName":"MySize"
Does anybody have a solution / workaround regarding this?
Thanks in advance!
Best answer by HelesicPetr
Hi @xolomon
I can see just only one workaround.
extends existing site, with own custom REST API function that does exactly what you need.
PetrH
HelesicPetr
Hi @xolomon
Be careful if you use display value or the internal value of the enumeration.
I guess that you should use the internal value.
And the question of the day, Is the internal value real;y "Small" ?
PetrH
xolomon14-AlexandriteAuthor
Hi @HelesicPetr,
thanks for the remark, I have been trying with both internal and external values. But unfortunately this is not the main problem.  It seems that OOTB only allows primitive, string and date variables in this area.
Cheeers,
Xolomon
Hi @HelesicPetr,
I have prepared already the custom endpoint in parallel for this purpose, but I would like know if someone had an idea without custom endpoint. My intention is to avoid customizations but if this is the only way then I have to provide the solution with the customization. We might report this as a product idea because it is such a basic functionality which could be supported with OOTB endpoints...
Thanks.
