OOTB Rest call of Document Domain "GetDocStructure" is not giving us the result in same order of doc
SKFPLMSupport
11-Garnet
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
Please include khushbu.vijayvargiya@hcltech.com , satishkumar.krish@hcltech.com , gokul.duraisamy@hcltech.com in the mail communication.
We are using OOTB Rest call of Documenet Domain "GetDocStructure" and we are using expand query "Structure($expand=Document($select=ID,Name,Number,Version,Description,State,TypeIcon,FolderLocation);$levels=2),Document($select=ID,Name,Number,Version,Description,State,TypeIcon,FolderLocation)" to fetch the require details.
but we are getting issue in this service as it is not giving us the result in same order of document what we see in windchill. In every hit it change the order of child document hence it is causing the issue for user to view as same in windchill.
Hi @SKFPLMSupport
It is common, that the order is different, and also it could be cased with database update time.
I recommend to sort the results before you display it to a user that the order is in expected view
PetrH
