Hi @OS_11417190,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
I have checked that , but want to know how bound data to this requests
Hi @OS_11417190
It is easy, just define the json input as you do for standard http requests and send it to the HTTP server
If you do not know how to create the request with JSON I do recommend to study something about it.
Content-Type: application/json
"Name":"BT002",
"Description":"Document Batch Test 002",
"Title":"Document TD002",
"Context@odata.bind": "Containers('OR:wt.pdmlink.PDMLinkProduct:95801')"
PetrH
Have you checked the batch request samples in the documentation?
https://support.ptc.com/help/windchill/r13.1.0.0/en/index.html#page/Windchill_Help_Center/WCRESTFramework/WCCG_RESTAPIsBatchSupport_examples.html
Hi @OS_11417190,
Thanks for using the PTC Community.
I wanted to let you know that there is an input to you on your topic. If you are in a position to respond to it, that would be great.
And, If it helped to answer your question, please mark it as the 'Accepted Solution.
Vivek N
