In Windchill version 11, it is posible to define the Revision when you create a new document but it is not when you select the option New Multiple Documents.
Several users have asked us for having it.
Set revision is not available in multiple document as there are no layout available - https://www.ptc.com/sitecore/content/support/Home/apps/ArticleViewer?n=CS127643 ,
Ok, I understand it but my proposal goes further. Could it be possible to add the revision field in the New Multiple wizard or creating a new specific layout associated to this action?
Thanks in advance.
I agree with you and it should be a product idea.
