Print different statements in different logger
AK_10341824
6-Contributor
Initially posted in this topic
Hi @HelesicPetr , I want to print different statements in different logger. Can you please help me here?
For example, I want different loggers purpose wise. Please refer to the below section.
private static final Logger LOGGER = LogManager.getLogger(LoggerExample.class );
private static final Logger LOGGER_PRE = LogManager.getLogger("LoggerExample_Pre");
private static final Logger LOGGER_SUMMARY = LogManager.getLogger("LoggerExample_Summary");
private static final Logger LOGGER_POST = LogManager.getLogger("LoggerExample_Post");
private static final Logger LOGGER_ERROR = LogManager.getLogger("LoggerExample_Error");
HelesicPetr
(To:AK_10341824)
Hi @AK_10341824
But in your config there is not definition for the Logger> LoggerExample_Pre
There is logger ext.test.LoggerExample
the LoggerExample_Pre definition is just appender that appends the ext.test.LoggerExample logger.
you need to define another logger with that name.
logger.LoggerExample_Pre.name=ext.test.LoggerExample_Pre
logger.LoggerExample_Pre.level=DEBUG
and so on...
PetrH
7 REPLIES 7
Here is what I do in my code:
Imports look like this for
import org.apache.logging.log4j.Logger; //updated for Log4J 2.x
import wt.log4j.LogR;
Note my update for Log4J 2.x as @HelesicPetr mentioned. In the code block I call out my logger which is typically the class name.
private static Logger log=null;
    static
        try
            log = LogR.getLogger(MyCustomClass.class.getName());
        catch(Exception e)
 In your example, I would just repeat that call for each one. Seems excessive but your call.
Hi @avillanueva , Can you please help me to configure these different log files for a single java code in log4jMethodserver.properties?
I entered for Pre logger only. But it was not working properly.
HelesicPetr
(To:AK_10341824)
Hi @AK_10341824
Please describe what is not working.
PetrH
@HelesicPetr ,
Please refer to the below sample code:
package ext.test;
import java.lang.reflect.InvocationTargetException;
import java.rmi.RemoteException;
import org.apache.logging.log4j.LogManager;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.util.WTException;
public class LoggerExample implements RemoteAccess {
private static final Logger LOGGER = LogManager.getLogger(LoggerExample.class);
    private static final int USERNAME_INDEX = 0;
    private static final int USERNAME_VALUE_INDEX = 1;
    private static final int PASSWORD_VALUE_INDEX = 3;
    private static int processedPartMasterCount = 0;
    private static int successfulPartMasterCount = 0;
    private static int failedPartMasterCount = 0;
    private static RemoteMethodServer rms;
public static void main(String[] args) throws RemoteException, InvocationTargetException {
LOGGER.debug("ENTER : LoggerExample.class.main(String[])");
        try {
            long startTime = System.currentTimeMillis();
            LOGGER.debug("LoggerExample.class StartTime : " + startTime);
            rms = getConnection(args);
            if (rms != null) {
            rms.invoke("doSomething", LoggerExample.class.getName(), null, new Class[] {}, new Object[] {});
                long endTime = System.currentTimeMillis();
                LOGGER.debug("LoggerExample.class EndTime : " + endTime);
                long totalTimeTaken = endTime - startTime;
                rms.invoke("printSummaryLogs", LoggerExample.class.getName(), null, new Class[] { Long.class }, new Object[] {totalTimeTaken});
        } catch (Exception e) {
            LOGGER.error("Exception occured while executing the utility.", e);
        LOGGER.debug("EXIT : LoggerExample.main(String[])");
    public static RemoteMethodServer getConnection(String[] args) throws WTException {
        LOGGER.debug("ENTER : LoggerExample.getConnection(String[])");
        String username = null;
        String password = null;
        if ("-u".equals(args[USERNAME_INDEX])) {
            username = args[USERNAME_VALUE_INDEX];
            password = args[PASSWORD_VALUE_INDEX];
        RemoteMethodServer remoteMethodServer = RemoteMethodServer.getDefault();
        if (username != null && !"".equals(username)) {
            remoteMethodServer.setUserName(username);
            if (password != null) {
                remoteMethodServer.setPassword(password);
        LOGGER.debug("EXIT : LoggerExample.getConnection(String[])");
        return remoteMethodServer;
    public static void doSomething() {
    LOGGER.debug("Inside doSomething() method...");
    LOGGER_PRE.debug("Inside doSomething() method...");
    LOGGER_SUMMARY.debug("Inside doSomething() method...");
    LOGGER_POST.debug("Inside doSomething() method...");
    LOGGER_ERROR.debug("Inside doSomething() method...");
    public static void printSummaryLogs(Long totalTimeTaken) {
        LOGGER.debug("ENTER : LoggerExample.printSummaryLogs(Long)");
        long totalTimeInMilis = totalTimeTaken.longValue();
        LOGGER.debug("Total time taken in miliSeconds : " + totalTimeInMilis);
        LOGGER_PRE.debug("Only for Pre log Inside printSummaryLogs() method...");
    LOGGER_SUMMARY.debug("Inside printSummaryLogs() method...");
    LOGGER_POST.debug("Inside printSummaryLogs() method...");
    LOGGER_ERROR.debug("Inside printSummaryLogs() method...");
        LOGGER_PRE.info("Logger Example :: Summary");
        LOGGER.info("=======================================");
        LOGGER.info("Number of traceable Part Master(s) : " + processedPartMasterCount);
        LOGGER.info("Number of succssfully updated Part Master(s) : " + successfulPartMasterCount);
        LOGGER.info("Number of Part Master(s) : " + failedPartMasterCount);
        LOGGER.debug("EXIT : LoggerExample.printSummaryLogs(Long)");
Log4jMethodServer.properties entries
logger.LoggerExample.name=ext.test.LoggerExample
logger.LoggerExample.level=DEBUG
logger.LoggerExample.appenderRef.LoggerExample_Pre.ref=LoggerExample_Pre
# Pre-logger
appender.LoggerExample_Pre.type = RollingFile
appender.LoggerExample_Pre.name = LoggerExample_Pre
appender.LoggerExample_Pre.createOnDemand = true
appender.LoggerExample_Pre.fileName = ${sys:wt.logs.dir}/LoggerExampleUtility/LoggerExample_Pre-${sys:wt.manager.serviceName}-${sys:wt.jvm.startTime.formatted.short}-${sys:wt.jvm.id}-log4j.log
appender.LoggerExample_Pre.filePattern = ${sys:wt.logs.dir}/LoggerExampleUtility/LoggerExample_Pre-${sys:wt.manager.serviceName}-${sys:wt.jvm.startTime.formatted.short}-${sys:wt.jvm.id}-log4j.log.%d{yyyy-MM-dd}_%i
appender.LoggerExample_Pre.layout.type = PatternLayout
appender.LoggerExample_Pre.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS}{${timeZone}} [%-5p]-[%t]-%c[%M] - %m%ex%n
appender.LoggerExample_Pre.policies.type = Policies
appender.LoggerExample_Pre.policies.midnight.type = SizeBasedMidnightTriggeringPolicy
appender.LoggerExample_Pre.policies.midnight.size=9MB
appender.LoggerExample_Pre.strategy.type = DefaultRolloverStrategy
appender.LoggerExample_Pre.strategy.max =2147483647
But I am getting output logs only for LOGGER.debug, LOGGER.info all these.
I need to get output in LOGGER_PRE.debug, LOGGER_POST.debug too.
HelesicPetr
(To:AK_10341824)
Hi @AK_10341824
and so on...
PetrH
Hi @HelesicPetr , thanks a lot for your help. It works.😃
HelesicPetr
(To:AK_10341824)
Hi @AK_10341824
The original post talk about configuration in the log4jMethodServer.properties
If you want to use your own logger in your code, use the LogR.getLogger
With this method, you can use any logger name. Not just class name.
for example I use logger for all classes in specific functionality.
LogR.getLogger("cz.aveng.WVSPublish");
the WVSPublish is not existing class
your logger could be
private static final Logger LOGGER_ERROR = LogR.getLogger("LoggerExample_Error");
PetrH
