I added the part and its associated Cad object into the workspace, I did checkout and check-in, I need to remove the object from the workspace programmatically which I added.
Issue: - I am unable to remove the objects from the workspace. Please suggest some ides to achieve this.
Isn't there a API for removing objects from Workspace?
There must be. Please look into the Javadoc.
Also, dependency should be looked at.
Are you able to remove the objects manually from the workspace?
Rgds
Hari
Hi Hari,
Yes.!. manually we can remove the objects from the workspace,
Regards
Raghavendra
Hi Fadel
Thank you.
I will try, it is Possible to create the Workspace and delete the created workspace programmatically, because instead of adding and removing the objects from the workspace, I think creation & deletion is the best solution.
Regards
Raghavendra
Hi
Solution is ok, but I wanted to create the workspace programmatically, and adding the objects into the newly created workspace, after the modification i wanted to delete the workspace.
Raikar
