Publishing customization
Keerthivarman
Version: Windchill 11.1
Use Case: Set publishing priority based on naming conventions
Description:
Hi Everyone,
I've a use case where I need to filter the files with naming conventions (Eg: mnpl) need to be published on high priority.
Here I need customization which need to be added in Windchill properties and sample code to get this achieved.
Thanks in advance,
Keerthi
2 REPLIES 2
Hi @Keerthivarman
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina
PTC Community Moderator
PTC
This article points to an example code that you can start with:
https://www.ptc.com/en/support/article/CS132318
