Version: Windchill 11.1
Use Case: Set publishing priority based on naming conventions
Description:
Hi Everyone,
I've a use case where I need to filter the files with naming conventions (Eg: mnpl) need to be published on high priority.
Here I need customization which need to be added in Windchill properties and sample code to get this achieved.
Thanks in advance,
Keerthi
Hi @Keerthivarman
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
This article points to an example code that you can start with:
https://www.ptc.com/en/support/article/CS132318
