Question regarding CASE 14107786: rest API findObjects doesn't filter objects based on soft-type
cgautier
18-Opal
Hi all, I need help regarding case 14107786.
It appears the findObjects REST API uses the findObjects() method from com/ptc/windchill/connected/plm/webservice/ObjectWebService and there is no possibility to filter on the subtype.
Are you aware of any valid workaround here?
amarsingh
(To:cgautier)
 @cgautier Try this Windchill REST Services API available at <windchill_server>:<port>/Windchill/servlet/odata/<different_domain>
Detail documentation can be found here https://www.ptc.com/en/support/refdoc/Windchill_REST_Services/1.5/wrs_ug_1_5
