Remove Organization Name Info
dmazaira
7-Bedrock
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.9
How remove the Organization Name in the Windchill notifications?
I follow the steps of CS312309 but not working
6 REPLIES 6
Hi @dmazaira
Thank you for your question.
It appears your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
avillanueva
23-Emerald I
(To:dmazaira)
Can you show or explain what you tried so far? Please post your email template and the result you are getting.
templateMail.jpg The Blue rectangle information it's that I want remove. I modify the NotificationRobot template, but only Apply in new Workflow Template.  It does not work, even if you iterate the workflow Template.  It's not working in the actual workflows process that are running and the new Workflow Process with a workflow Template created before the change..
avillanueva
23-Emerald I
(To:dmazaira)
I've done some email modifications but I did not remove that part. I think its added to the template somewhere else.
HelesicPetr
(To:dmazaira)
Hi @dmazaira
You have to redesign the full html page to just add only the information you need.
If you need to remove specific information, you can not use the <SCRIPT LANGUAGE=Windchill><!--
activityAttributes--></SCRIPT>
you have to write own html page based on rules described in a Help
Workflow Email Notifications
PetrH
Hi @dmazaira ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC
