Removing stiptoken Parameter in Windchill REST API
ozclkonur
When using the Windchill REST API, I am limited to receiving only 25 records by default due to the stiptoken=25 parameter. However, I want to retrieve all the data, so how can I remove the stiptoken parameter via the API? Can you assist me with this?
HelesicPetr
(To:ozclkonur)
Hi @ozclkonur
Have you tried to use some very high number that you always know that there are not so many records?
For example bumbilion ? 100000000000
PetrH
ANNA_02
(To:ozclkonur)
Refer this article,
https://www.ptc.com/en/support/article/CS340471?source=search
Max number of results for each response limited to 2000.
You would have to parse the response and check if it has "@odata.nextLink" if so retrieve the next url and so on.
