Resouce for workflow code writing
lgrant
I am in need of a resource for workflow code writing?
We are on Windchill PDMLink 11, M020
Nothing very complicated.
On a CR, I need a bit of code that would:
If primaryBusinessObject = INWORK then set sate UNDERREVIEW, else do nothing.
Any item on a CR that is submitted that is in a In Work state should be set to Under Review. If it's not in a state of In Work then do nothing to that item.
I would then also need to back that out again on a rework loop. If its Under Review then set to In Work, if its anything else then do nothing to that item.
BineshKumar1
(To:lgrant)
        try {
            wt.change2.WTChangeRequest2 changeRequest = (wt.change2.WTChangeRequest2) primaryBusinessObject;
            //Query & loop through the change request to get all the changeables
            wt.fc.QueryResult affectedObjects = wt.change2.ChangeHelper2.service.getChangeables((wt.change2.ChangeRequestIfc) changeRequest, true);
            while(affectedObjects.hasMoreElements()) {
                wt.lifecycle.LifeCycleManaged object = (wt.lifecycle.LifeCycleManaged)affectedObjects.nextElement();
                String state = object.getLifeCycleState().toString();
                // if the lifecycle state is design, set it to release review or else do nothing.
                if(state.equalsIgnoreCase("INWORK")) {
                    wt.lifecycle.LifeCycleHelper.service.setLifeCycleState (object, wt.lifecycle.State.toState ("UNDERREVIEW"));
        } catch (wt.util.WTException e) {
            e.printStackTrace();
12 REPLIES 12
BineshKumar1
(To:lgrant)
The easiest option would be to define the lock state and use the Method  transitionTargets(Object theObject, Transition transition, boolean failIfNoTransitionExists) to set the affected objects to a lock state defined by LC template. But I am not sure, whether this work for CR, I have used this for CN.
        try {
                LifeCycleManaged object = (LifeCycleManaged)affectedObjects.nextElement();
                if(state.equalsIgnoreCase("design") {
                    LifeCycleHelper.service.setLifeCycleState (object, State.toState ("RELEASE_REVIEW"));
        } catch (WTException e) {
lgrant
(To:BineshKumar1)
For that to work, each object type we manage (wtPart, EPMdocument, etc.) would need to have lock selected at In Work ?
 try {
                // if the lifecycle state is INWORK, set it to UNDERREVIEW or else do nothing.
                if(state.equalsIgnoreCase("INWORK") {
                    LifeCycleHelper.service.setLifeCycleState (object, State.toState ("UNDERREVIEW"));
BineshKumar1
(To:lgrant)
That's correct. But I am not sure whether lock method works for Change Request. It works for change notice, change task or even promotion request.
The code which had in my previous post will work without any lock transition
BineshKumar1
(To:lgrant)
Since the "lock" method is well-proven over many releases for Promotion, would definitely be best to utilize that approach if at all possible.
lgrant
(To:BineshKumar1)
Any idea what the error is?
RandyJones
20-Turquoise
(To:lgrant)
You are missing a closing ')'
if(state.equalsIgnoreCase("INWORK")) <---------
lgrant
(To:RandyJones)
After adding in the missing )
I now have a new list of errros.
Checking Syntax...
/opt/ptc/Windchill_9.0/Windchill/tmp/WfExpression332772435.java:59: error: cannot find symbol
symbol: class QueryResult
/opt/ptc/Windchill_9.0/Windchill/tmp/WfExpression332772435.java:61: error: cannot find symbol
symbol: class LifeCycleManaged
/opt/ptc/Windchill_9.0/Windchill/tmp/WfExpression332772435.java:65: error: cannot find symbol
symbol: variable State
/opt/ptc/Windchill_9.0/Windchill/tmp/WfExpression332772435.java:65: error: package LifeCycleHelper does not exist
/opt/ptc/Windchill_9.0/Windchill/tmp/WfExpression332772435.java:68: error: cannot find symbol
symbol: class WTException
Note: /opt/ptc/Windchill_9.0/Windchill/tmp/WfExpression332772435.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
6 errors
Syntax check complete.
BenPerry
(To:lgrant)
In the workflow Execute Expression robots, you need to use full path of the java classes & methods.  So instead of just LifeCycleManaged, use wt.lifecycle.LifeCycleManaged.  Same with LifeCycleHelper.
I think you still have some more errors to fix, but this will reduce a little.  Then you can focus on what is left.
lgrant
(To:BenPerry)
few less errors. Community project at its best 🙂
Checking Syntax...
wt.lifecycle.LifeCycleManaged object = (LifeCycleManaged)affectedObjects.nextElement();
wt.lifecycle.LifeCycleHelper.service.setLifeCycleState (object, State.toState ("UNDERREVIEW"));
4 errors
BineshKumar1
(To:lgrant)
        try {
lgrant
(To:BineshKumar1)
Now that is what the cummunity page is for. Thanks everyone.
