Hi all,
I need to retrieve template reports via the OData API. I have used the following API
/Windchill/servlet/odata/IE/InvokeIETask
"Task": "com/ptc/windchill/enterprise/report/ExecuteReportTemplate.xml",
"Params": [
"Name": "object_ref",
"Value": "wt.query.template.ReportTemplate:1234"
now i need to change the report criteria directly from the API. i tried to add a parameter but it doesn't seem to work. where can i find documentation? what is the correct parameter to pass?
I have this criteria
Any suggestions?
