I would like to get a List of .drw who changed the lifecycle state within the last 24 h. There is a restriction to get the information via REST Endpoint.
I used the PTC CAD Document management with GET CADDocuments. I tried to use the filter for the LastModified date. But there is no impact of a changed Lifecycle state to the Last modified date.
Any Ideas how i can filter for objects who changed their lifecycle state in a range of time?
It can be done without customisation using InvokeIETask to invoke a ExecuteReportTemplate task.
Create a report using the query builder and define parameters to filter for the date, then execute the report via REST.
Endpoint: Windchill/servlet/odata/v1/IE/InvokeIETask
Task: com/ptc/windchill/enterprise/report/ExecuteReportTemplate2.xml
Body E.g.
"Value":"wt.query.template.ReportTemplate:664683966",
"Name":"object_ref"
"Value":"cname=" + searchString,
"Name":"input"
where cname is the name of parameter mapped to criteria in Query builder report
Body E.g.
"Name":"object_ref"
"Name":"input"
I would recommend same way. use report template and query builder to define own collection of objects and call it by the API
for example I use ExecuteReportTemplate
Example: Viewing the output of Report Template execution
PetrH
