Team
According to this Help page below, SL is compatible with DTI. Too many acronyms!
I have SL configured to pop up a Download Confirmation message window and wait for acknowledgement. However this just works for normal file downloads. When I set the preference so I am using DTI, there is a blank popup which disappears immediately.
Hi @rleir
If you say I have SL configured to popup... Does it mean a OOTB configuration or customization?
PetrH
Petr
It is an OOTB Security Labels config, without the Agreements options. But any work with Security Labels feels like customization because when you make a mistake Windchill fails to start and you are digging through log files. I hear that you can get a crash when the acknowledgement window pops up due to an config error. That's just hearsay, apologies.
So you're right, this question technically should not be in the Customization forum!
Maybe I should set the logging level to Info or Debug. But would I set that system-wide? I want to see what goes wrong when you download via DTI.
Or maybe I should dig in and check if DTI was installed correctly.
cheers
Specifically, the problem is that when using DTI, there is a blank download ack popup which disappears immediately.
When not using DTI, just the simple download preference, the download ack popup works correctly.
Hi @rleir
The point is that the DTI file is downloaded directly that is used by DTI.
I guess that there is a some condition that standard download mechanism is bypassed and it works as you've described.
PetrH
