Version: Windchill 12.1
Use Case: Uploading CAD documents generates a sequence (00001234) number instead of name.
Description:
Our windchill system has always been setup such that any files that dont auto associate to existing parts are assigned a 10 digit sequential number. How do I change it so that files checked in are are given a number the same as the model - ASM001.asm associates to a part with the number ASM001 instead of 00001234?
You need to change the Object Initialization Rules to remove auto-numbering.
How to turn on/off the Autonumbering for object types in Windchill PDMLink
In the site preferences, there are a number of preferences that control how numbering is mapped for CAD files, dropping extensions and mapping to the WTParts.
I set the preferences, but I couldn't get the autonumbering to disable.
I looked at that article, but my OIR looks like its different and the code to comment out doesn't exist?
Edit: Nevermind - I was editing the wrong "Number" section. All is working now!
