package ext.utility
import wt.associativity.EquivalenceLink;
import wt.change2.WTChangeActivity2;
import wt.change2.WTChangeIssue;
import wt.change2.WTChangeOrder2;
import wt.change2.WTChangeRequest2;
import wt.doc.WTDocument;
import wt.epm.EPMDocument;
import wt.epm.structure.EPMDescribeLink;
import wt.epm.structure.EPMMemberLink;
import wt.epm.structure.EPMReferenceLink;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.fc.PersistenceServerHelper;
import wt.fc.QueryResult;
import wt.maturity.PromotionNotice;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.part.WTPart;
import wt.part.WTPartAlternateLink;
import wt.part.WTPartDescribeLink;
import wt.part.WTPartUsageLink;
import wt.query.QuerySpec;
import wt.session.SessionServerHelper;
import wt.util.WTException;
import wt.util.WTPropertyVetoException;
import wt.vc.VersionControlHelper;
import wt.vc.wip.WorkInProgressHelper;
import wt.vc.wip.Workable;
import wt.workflow.work.WorkItem;
public class DataDeletionUtility implements RemoteAccess {
* Through this utility we are deleting data from windchill. The objects targeted are:
* 1.Part Usage Links
* 2.Part Describe Links
* 3.Equivalence Links
* 4.Part Alternate Links
* 5.EPM Describe links
* 6.EPM Uses links
* 7.EPM Reference Links
* 8.Change Notices
* 9.Change Requests
* 10.Change Activity
* 11.Problem Reports
* 12.Promotion Requests
* 13.EPM Documents
* 14.WTParts
* 15.WTDocuments
* Run this command on windchill shell:
* windchill ext.utility.DataDeletionUtility
* to run this utility
public static RemoteMethodServer getMS() {
return RemoteMethodServer.getDefault();
public static void main(String[] argv) {
try {
RemoteMethodServer rms = getMS();
rms.setUserName("wcadmin");
rms.setPassword("wcadmin");
rms.invoke("run", "ext.utility.DataDeletionUtility", null, null, null);
} catch (Exception e) {
e.printStackTrace();
} finally {
System.exit(0);
public static void run() throws Exception {
Boolean enforced = SessionServerHelper.manager.isAccessEnforced();
SessionServerHelper.manager.setAccessEnforced(false);
deleteChangeObjects();
deleteEqLinks();
deletePartUsageLinks();
deleteDescribeLinks();
deletePartAlternateLinks();
deleteEPMDescribeLinks();
deleteEPMUsesLinks();
deleteEPMReferenceLinks();
deleteParts();
deleteDocuments();
deleteEPMDocument();
SessionServerHelper.manager.setAccessEnforced(enforced);
@SuppressWarnings("deprecation")
public static void deletePartUsageLinks() throws Exception {
System.out.println("Deleting part usage links..");
QuerySpec querySpec = new QuerySpec(WTPartUsageLink.class);
QueryResult links = PersistenceHelper.manager.find(querySpec);
while (links.hasMoreElements()) {
Persistable link = (Persistable) links.nextElement();
try {
System.out.println("Deleting link: " + link);
PersistenceServerHelper.manager.remove(link);
} catch (WTException e) {
System.err.println("Failed to delete link: " + link);
public static void deleteDescribeLinks() throws Exception {
System.out.println("Deleting part describe links..");
QuerySpec querySpec = new QuerySpec(WTPartDescribeLink.class);
try {
public static void deleteEqLinks() throws Exception {
System.out.println("Deleting equivalence links..");
QuerySpec querySpec = new QuerySpec(EquivalenceLink.class);
QueryResult eqlinks = PersistenceHelper.manager.find(querySpec);
while (eqlinks.hasMoreElements()) {
Persistable link = (Persistable) eqlinks.nextElement();
try {
public static void deletePartAlternateLinks() throws Exception {
System.out.println("Deleting part alternate links..");
QuerySpec querySpec = new QuerySpec(WTPartAlternateLink.class);
try {
public static void deleteEPMDescribeLinks() throws Exception {
System.out.println("Deleting EPM describe links..");
QuerySpec querySpec = new QuerySpec(EPMDescribeLink.class);
QueryResult epmDescLinks = PersistenceHelper.manager.find(querySpec);
while (epmDescLinks.hasMoreElements()) {
Persistable link = (Persistable) epmDescLinks.nextElement();
try {
System.err.println("Failed to delete epm desc link: " + link);
public static void deleteEPMReferenceLinks() throws Exception {
System.out.println("Deleting EPM ref links..");
QuerySpec querySpec = new QuerySpec(EPMReferenceLink.class);
QueryResult epmRefLinks = PersistenceHelper.manager.find(querySpec);
while (epmRefLinks.hasMoreElements()) {
Persistable link = (Persistable) epmRefLinks.nextElement();
try {
System.err.println("Failed to delete epm ref link: " + link);
public static void deleteEPMUsesLinks() throws Exception {
System.out.println("Deleting EPM uses links..");
QuerySpec querySpec = new QuerySpec(EPMMemberLink.class);
QueryResult EPMUsesLinks = PersistenceHelper.manager.find(querySpec);
while (EPMUsesLinks.hasMoreElements()) {
Persistable link = (Persistable) EPMUsesLinks.nextElement();
try {
System.err.println("Failed to delete epm uses link: " + link);
public static void deleteChangeObjects() throws Exception {
System.out.println("Deleting change objects..");
QuerySpec querySpec1 = new QuerySpec(WTChangeOrder2.class);
QueryResult CN = PersistenceHelper.manager.find(querySpec1);
while (CN.hasMoreElements()) {
Persistable persCN = (Persistable) CN.nextElement();
try {
System.out.println("Deleting CN: " + persCN);
PersistenceServerHelper.manager.remove(persCN);
System.err.println("Failed to CN: " + persCN);
QuerySpec querySpec2 = new QuerySpec(WTChangeRequest2.class);
QueryResult CR = PersistenceHelper.manager.find(querySpec2);
while (CR.hasMoreElements()) {
Persistable persCR = (Persistable) CR.nextElement();
try {
System.out.println("Deleting CR: " + persCR);
PersistenceServerHelper.manager.remove(persCR);
System.err.println("Failed to CR: " + persCR);
QuerySpec querySpec3 = new QuerySpec(WTChangeActivity2.class);
QueryResult CA = PersistenceHelper.manager.find(querySpec3);
while (CA.hasMoreElements()) {
Persistable persCA = (Persistable) CA.nextElement();
try {
System.out.println("Deleting link: " + persCA);
PersistenceServerHelper.manager.remove(persCA);
System.err.println("Failed to delete link: " + persCA);
QuerySpec querySpec7 = new QuerySpec(WorkItem.class);
QueryResult workItem = PersistenceHelper.manager.find(querySpec7);
while (workItem.hasMoreElements()) {
Persistable task = (Persistable) workItem.nextElement();
try {
System.out.println("Deleting tasks: " + task);
PersistenceServerHelper.manager.remove(task);
System.err.println("Failed to delete task: " + task);
QuerySpec querySpec4 = new QuerySpec(WTChangeIssue.class);
QueryResult problemReports = PersistenceHelper.manager.find(querySpec4);
while (problemReports.hasMoreElements()) {
Persistable pr = (Persistable) problemReports.nextElement();
try {
System.out.println("Deleting Problem reports: " + pr);
PersistenceServerHelper.manager.remove(pr);
System.err.println("Failed to Problem reports: " + pr);
QuerySpec querySpec5 = new QuerySpec(PromotionNotice.class);
QueryResult problemNotice = PersistenceHelper.manager.find(querySpec5);
while (problemNotice.hasMoreElements()) {
Persistable pn = (Persistable) problemNotice.nextElement();
try {
System.out.println("Deleting Promotion Notice: " + pn);
PersistenceServerHelper.manager.remove(pn);
System.err.println("Failed to Promotion Notice: " + pn);
public static void deleteEPMDocument() throws WTException {
System.out.println("Deleting EPM document..");
QuerySpec querySpec = new QuerySpec(EPMDocument.class);
QueryResult docs = PersistenceServerHelper.manager.query(querySpec);
while (docs.hasMoreElements()) {
EPMDocument epmdoc1 = null;
try {
Persistable epmdoc = (Persistable) docs.nextElement();
if(epmdoc instanceof EPMDocument) {
epmdoc1 = (EPMDocument) epmdoc;
QueryResult result = VersionControlHelper.service.allIterationsOf(epmdoc1.getMaster());
while(result.hasMoreElements()) {
System.out.println("Deleting EPM document: " + epmdoc1.getNumber());
Persistable doc2= (Persistable) result.nextElement();
if(WorkInProgressHelper.isCheckedOut((Workable) doc2)) {
WorkInProgressHelper.service.checkin((Workable) doc2,"Checkin via api");
PersistenceHelper.manager.delete(doc2);
}catch (Exception e) {
System.err.println("Failed to delete epm doc: " + epmdoc1.getNumber());
public static void deleteParts() throws WTException, WTPropertyVetoException {
System.out.println("Deleting parts..");
QuerySpec querySpec = new QuerySpec(WTPart.class);
QueryResult parts = PersistenceServerHelper.manager.query(querySpec);
while (parts.hasMoreElements()) {
WTPart part1 = null;
try {
Persistable part = (Persistable) parts.nextElement();
if(part instanceof WTPart) {
part1 = (WTPart) part;
QueryResult allIterations = VersionControlHelper.service.allIterationsOf(part1.getMaster());
while(allIterations.hasMoreElements()) {
System.out.println("Deleting part: " + part1.getNumber());
Persistable part2= (Persistable) allIterations.nextElement();
if(WorkInProgressHelper.isCheckedOut((Workable) part2)) {
WorkInProgressHelper.service.checkin((Workable) part2,"Checkin via api");
PersistenceHelper.manager.delete(part2);
System.out.println("Deleting part: " + ((WTPart)part).getNumber());
System.err.println("Failed to delete part: " + part1.getNumber());
public static void deleteDocuments() throws WTException, WTPropertyVetoException {
System.out.println("Deleting docs..");
QuerySpec querySpec = new QuerySpec(WTDocument.class);
QueryResult docq = PersistenceServerHelper.manager.query(querySpec);
while (docq.hasMoreElements()) {
WTDocument doc1 = null;
try {
Persistable doc = (Persistable) docq.nextElement();
if(doc instanceof WTDocument) {
doc1 = (WTDocument) doc;
QueryResult allIterations = VersionControlHelper.service.allIterationsOf(doc1.getMaster());
System.out.println("Deleting doc: " + doc1.getNumber());
Persistable doc2 = (Persistable) allIterations.nextElement();
PersistenceHelper.manager.delete( doc2);
System.err.println("Failed to delete doc: " + doc1.getNumber());
@KP_11714888 thanks. looks good.
This will also delete all the Document-, Change Order-, CAD-Document templates. Probably these should be ignored.
Yeah, you can definitely modify the code based on specific requirements. In my case, I needed to delete everything—including Documents, Change Objects, and CAD templates. Thanks! @BjoernRueegg
I want to delete the link between two documents i.e. WTDocumentDependencyLink based on the given WTDocument.
Can you help me with the how do I get link object here so that i can delete it using PersistenceHelper
