Templating a change review object
Dobi
Version: Windchill 13.0
Use Case: Would like to have a change review object template (like we do for change notices)
Description:
Two part question as I'm starting to play more with change review objects.
  1. These are considered Change objects... so why is it that they can't be templated on the Templates tab like change notices can?
  2. I'd like to add a table to the long description field of the peer review object. Keeping in mind the first question, is there a way to do this without templating the object?
Hi @Dobi,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
