The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
Can the boxes of parameters that are resettable for an Change Task Activity be enlarged?
Try this: ( I used document type)
Input field type for the attribute has to be Multiple Lines
Go to actions > Edit on the type, then click layouts, the attribute, then the pencil above the attribute
Edit number of columns and number of rows
@jbailey these are not part of the layout, but are part of the task that are defined here as visible.
Hm, I figured you could do it with one of the layouts under work item, since the task completion is a work item 😐
I just used document since I already had some multi-line attributes there
Would have been nice. The problem is that different tasks have different attributes, especially when you start to have workflows for different things other than CNs.
It looks like a good starting point. I need to get my dev server up and running before I want to test this.
