Version: Windchill 13.0
Use Case: I am trying to access an API in the change management domain which GETs some data and i want to make a get call using a filter by the name "Owner" which is of PTC.PrincipalMgmt.User type, trying to build a simple filter query here but when using queries like Owner eq " OwnerName " I get an error : { "error": { "code": null, "message": "The types 'PTC.PrincipalMgmt.User' and 'Edm.String' are not compatible." } } which clearly signals that the query format is wrong since i need to pass the object and i have passed string. So what change do i need to perform in my GET call.
Description:
"error": {
"code": null,
hi,
Can you share the snippet of code where you do the query?
Please share the REST URL which you are trying to exceute for Change object ?
