Hi All
I have a customization that displays the structure of a selected part with the columns being thier attributes in a JSP. All the columns are editable with textboxes in each row. I have a find and replace function in that page that allows me to replace text in mass. But I'm unable to do it as beyond a particular row count, when I try to find a text using document.getElementById it returns null. I tried the solution https://www.ptc.com/en/support/article/CS132804 which disables redrawing rows but still no luck. I'm able to do it only when I scroll through the entire table and load all the rows manually. Is there any workaround or is there any script that would load all rows of a table.
