Unable to get user comments and votes while approving the promotion request or approve tasks.
@_1647
Hi Sumit,
I have a custom utility on Promotion Notice and I want to retrieve all task data like name, number, role, assignee, activity name, vote, and comments as well. So, I  retrieved all the data but I am STRUGGLING to get user comments and votes while approving the promotion request or while performing the "approve" task.
If you have sent a snap of code then it would be highly appreciated.
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
You may run the code in wrong place 😄 getParent just return WF process, in your case there is assignedActivity so you need to solve it.
Check what the method getParentProcess returns. It should be WfProcess
I suggest you to use IDE and test class function to test a code, not just run it in the workflow...
For example run http url to run your method and see if it works or not.
PetrH
7 REPLIES 7
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
If you need a help can you share your code where you try to get that information?
PetrH
I have pbo as promotion notice and i got the other detail as below but comments and Assignee Name is not getting as who is approver or reviewer not getting :
Vote Getting as Null
System.out.println("workitem activityName is :
((wt.workflow.work.WfAssignedActivity) workitem.getSource().getObject()).getName());
System.out.println("workitem role is :" + workitem.getRole().getFullDisplay());
System.out.println("workitem vote is :" + workitem.getEventSet().toString());
System.out.println("WorkItem owner is :" + workitem.getOwnership().getOwner().getFullName());
System.out.println("WorkItem getCompletedBy is :" + workitem.getCompletedBy());
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
You need to get WfVotingEventAudit  object
// (wt.workflow.work.WfAssignedActivity)activity
wt.fc.collections.WTArrayList auditCol = (wt.fc.collections.WTArrayList) wt.workflow.engine.WfEngineHelper.service.getVotingEvents((wt.workflow.engine.WfProcess) activity.getParentProcess(), null, null, null);
PetrH
Yes I want that but I am not getting an API. I will try your shared one
getting error on BGMS : Caused by: java.lang.ClassCastException: class wt.workflow.engine.WfProcess cannot be cast to class wt.workflow.work.WfAssignedActivity (wt.workflow.engine.WfProcess and wt.workflow.work.WfAssignedActivity are in unnamed module of loader 'app')
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
PetrH
Hello @@_1647
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
