I am trying to update the WTVariance object IBA but can't see the updated values can any one help me how I can do this using code
I am using this code right now
| try{ |
wt.change2.WTVariance var = (wt.change2.WTVariance)primaryBusinessObject;
com.ptc.core.lwc.server.LWCNormalizedObject obj = new com.ptc.core.lwc.server.LWCNormalizedObject(var , null,java.util.Locale.US, null);
obj.load(att);
obj.set(att,attValue);
obj.apply();
//PersistenceHelper.manager.refresh(var );
catch (wt.util.WTException e) {
e.printStackTrace();
HI @A D,
Please refer below code snippet for your reference.
Note: This example code is just for your reference. Kindly verify it on test server first.
public class UpdateWTVariance implements RemoteAccess {
* @param args
* @throws InvocationTargetException
* @throws RemoteException
public static void main(String[] args) throws RemoteException, InvocationTargetException {
RemoteMethodServer rms = RemoteMethodServer.getDefault();
rms.setUserName("wcadmin");
rms.setPassword("ts");
rms.invoke("updateVarianceIBA", ext.UpdateWTVariance.class.getName(), null, null, null);
public static void updateVarianceIBA() throws WTException {
ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.change2.WTVariance:2336782");
WTVariance var = (WTVariance) PersistenceHelper.manager.refresh(oid);
System.out.println("Variance Name: " + var.getName());
PersistableAdapter theIBAs = new PersistableAdapter(var, null, java.util.Locale.US, new UpdateOperationIdentifier());
theIBAs.load("savedAmount");
theIBAs.set("savedAmount","14562");
theIBAs.apply();
// Persisting IBA Value
PersistenceHelper.manager.modify(var);
System.out.println(" *** Update Success *** ");
I hope this helps you.
Shirish
Hi Shirish,
Thank you so much for your help yes it worked for me
sorry for late reply
