Use of getSpecialTableColumnsAttrDefinition Method While creating Table Views from Table Builders?
TDT
The PTC Help Center recommends overriding the getSpecialTableColumnsAttrDefinition() method to include new attributes.
However, when I click "Customize" in the table view, all attributes for the selected object type already appear under "Set Column Display."
Is there a specific reason or scenario where overriding getSpecialTableColumnsAttrDefinition() is needed?
TDT
(To:TDT)
The getSpecialTableColumnsAttrDefinition method is used to define a custom table column that is not stored in or related to any object, and to display its value using a data utility
The getSpecialTableColumnsAttrDefinition is used along with getOOTBTableViews
@Override
public List<?> getSpecialTableColumnsAttrDefinition(Locale locale) {
ArrayList localArrayList = new ArrayList();
localArrayList.add(AttributeHelper.newStringAttribute("customAttribute",
WTMessage.getLocalizedMessage(TestResource.class.getName(), "CUSTOM_ATTRIBUTE", null, locale)));
return localArrayList;
The customAttribute is used as the selector value to register the data utility.
