This widget could not be displayed.
Validate attribute values during save as after finish for EPM Document using customization
11091925
Version: Windchill 13.0
Use Case: I need to validate few attribute in save as window once use click on finish, Below is the use case 1. Use will perform save as CAD Document 2. Collected WtParts and Drawings 3. Fill global attribute on CAD Document and finish Need to validate the attribute upon finish. Please do let me know if any one worked on this kind of customization
Description:
Validate global IBAs during save as wizard
HelesicPetr
(To:joe_morton)
Hi @11091925
I agree with @joe_morton the listener service is the easier way how to achieve what you need..
PetrH
Hi @11091925
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
Sounds like you would need some kind of Listener to interrupt the save as if validation is failed. We haven't quite got there.
The closest we have is fixing save as issues after the fact, using data monitors to alert admins when data  with errors was created (by any method, not just save as).
It definitely would be nice to prevent the issues in the first place!
HelesicPetr
(To:joe_morton)
Hi @11091925
PetrH
