Version sync in Workflow
I want to customize the version synchronizations for the part, cad and drawing data we use in windchill. I don't want to do this manually. Is it possible to create a flow for this process and take part data codes from users in this flow and synchronize these codes to the most current version in the workflow? If we do the version synchronization process in the workflow, will there be a problem in connecting the data with each other?
