Versions/Iterations for Part Instances
Turko
Version: Windchill 13.0
Use Case: I am trying to trace how a part instance (not a part) develops over time. I know that with parts, it is possible to view revision and version/iteration history. However, this does not seem to be the case for part instance objects (with the OOTB configuration at least).
Description:
If I had an existing part instance that was associated with a part configuration and I then edited the instance to make use of a different configuration, it seems that I have no way of being able to see that the instance was originally associated to the configuration it was initially configured to use. This is unless I change the revision of the part instance. In which case, the "History" tab of the instance would show the differences between the two revisions. Is there any way I can track changes made to a part instance prior to any increase of the revision for the instance, like I would be able to track the version/iteration history of a part between revision changes?
Catalina
Moderator
(To:Turko)
Hi @Turko
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
