WINDCHILL MULTIVALUED API
VM_10716163
Looking for API to set multiValue Attribute in create page of Promotion Request.
Values are taken from another MultiValued attribute.
EG:
Product under which PR is getting created has attribute A with values A,B,C
When I am creating Promotion request , attribute in PR should take values from that attribute of product (Multivalued and editable)
Help would be appriciated.
HelesicPetr
(To:VM_10716163)
Hi @abhishekarya
In the crate wizard a promotion request object does not exists so you can not get them.
In data utility in the crate wizard you can get a context where the wizard is activated and get the parameter from that context (product library)
Also the multivalued attributes are separated by "@" character
PetrH
3 REPLIES 3
Get Multi IBA Value :
PersistableAdapter chObj;
chObj = new PersistableAdapter(persistable, null, Locale.US, null);
chObj.load(s);
Object ibaObject= chObj.get(s);
LOGGER.debug("getIBAValue: " + chObj.getAsString(s));
return ibaObject;
When you use above method, you can just check the instance of and see if its an array and parse multi values to set:
if (objValue instanceof Object[]) {
  Object values[] = (Object[]) objValue;
          for (Object value : values) {
          basePartFinishCodes.add(value.toString());
Set Multi IBA Value, you just need to pass an Array of values to set:
PersistableAdapter adapter = new PersistableAdapter(obj, null, Locale.US, null);
adapter.load(attrName);
adapter.set(attrName, value);
obj = adapter.apply();
IBAValueDBService ibaserv = new IBAValueDBService();
ibaserv.updateAttributeContainer((IBAHolder)obj, ((DefaultAttributeContainer)((IBAHolder)obj).getAttributeContainer()).getConstraintParameter(),null,null);
PersistenceServerHelper.manager.update(obj);
Hello Abhishek,
Thanks for your response.
But in create page of PR , I am not seeing object as Promotion request.
Object is coming as wtpart on which this PR is getting created?
How can I get PR object (in Data utility Create page)
HelesicPetr
(To:VM_10716163)
Hi @abhishekarya
PetrH
