We are trying to export a "report" that will show the CAD models related to a given Windchill Part. Or the other way around; a report that shows what Windchill Part is related to a given CAD model. We would like this to be able to search thru more than one given, but could even live with just spitting out the whole of the WT Part folder. We also are trying to do so from a Windchill user standpoint, but might be able to get the Windchill admin to help if it isn't too involved.
Any thoughts or suggestions?
Thanks in advance!
Here is a QML report that you can import to the site or org level. You can modify the select output as you need but links Parts to CAD docs.
Thanks... I guess. This is over my head, I'm guessing. I don't know what you mean by "import to site or org level" or what a QML file does. Sorry... just a "user" here, no Windchill administration at all.
He provided a report template that an administrator will have to load into your system, and modify it accordingly.
