WRS : How to overcome Conflicting versions of domain ChangeMgmt are being imported: Versions 5 and 6
KiranG
3-Newcomer
{         "code": "CONFIGURATION_ERROR_CONFLICTING_DOMAIN_VERSIONS",         "message": "Conflicting versions of domain ChangeMgmt are being imported: Versions 5 and 6"     }
3 REPLIES 3
VladimirN
(To:KiranG)
Article - "Method Server shows error "Conflicting versions of domain being imported: DomainName: ChangeMgmt Versions: 5 and 6" while accessing custom domain REST Services in Windchill REST Services": https://www.ptc.com/en/support/article/CS388854
KiranG
3-Newcomer
(To:VladimirN)
I tries the solution mentioned in the Article, But solution approach is not working, Please share any working example for this problem,
HelesicPetr
(To:KiranG)
Hi @KiranG
If you ask for example, Please can you share yours not working example?
PetrH
