Hi @AK_12943638
You have to do it manually, There is no API that support the template type change.
1. Create new template as a subtype of a change task.
2. Disable the root template.
Also you can check an existing tool.
There is a utility that can be used to change a object type but, it works just for all objects of the type.
CS368420 - How to change type of existing objects with "ChangeTypeSql" utility in Windchill
Change the Type of the Existing Objects in Windchill PDMLink
PetrH
Hello @AK_12943638,
It looks like you have a response from our community champion. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
