In the KB of PTC support there are summary articles by homogeneous themes (HUB articles).
If you search with the keywords HUB, InfoEngine, and Jasper you should find this article first
[Knowledge Hub] Windchill PLM - Jasper Report
Inside you will find this one
[Knowledge Hub] Windchill PLM - Jasper Report with Info Engine
I hope they can be useful to you
Have you already looked at this article?
How to add the custom attributes to Change Notice Log report and Change Request Log report
Thanks Marco for sharing the article.
I tried the solution mentioned in the link to add a custom attribute to the Change Notice Log. It worked.
I have requirement to copy existing report and modify it to add our custom attributes ( type /rel attributes ) . If I modify existing infoEngine xml as mentioned in the link , it will impact the report Windchill provides OOTB. Do you know if I can use Jasper Studio to modify the Report Output ( displaying data in tables ) ? If Yes , how can I link it to the infoEngine task ? How do I create one ?
Is there any documentation/link/samples do you have which can help me understand how to create a Jasper report with steps. I tried to go through the PTC link below , I could not proceed much.
Thanks . I will go through the links.
