We have a requirement to customize Windchill Change Summary Repot to include IBM custom attributes.
AK_10131364
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.0.2
We have a requirement to export OOTB Windchill Change Summary Report ( Change Notice -> Actions -> View Summary Report ) , copy it and extended to include our IBM specific object, relationship, attribute information.
I believe , the OOTB report uses infoEngine tasks as a datasource to fetch the data from Windchill.So we need copy the OOTB template and implement new infoEngine Tasks to fetch the required IBM data , along with the one windchill provides OOTB.
Do you suggest we follow this approach to use infoEngine tasks ? Do you know if PTC plans to discontinue the infoEngine tasks in future ?
If so , do you have any suggestions on the alternate approach ?
In the KB of PTC support there are summary articles by homogeneous themes (HUB articles).
If you search with the keywords HUB, InfoEngine, and Jasper you should find this article first
[Knowledge Hub] Windchill PLM - Jasper Report
Inside you will find this one
[Knowledge Hub] Windchill PLM - Jasper Report with Info Engine
I hope they can be useful to you
Marco
Thanks Marco for sharing the article.
I tried the solution mentioned in the link to add a custom attribute to the Change Notice Log. It worked.
I have requirement to copy existing report and modify it to add our custom attributes ( type /rel attributes ) . If I modify existing infoEngine xml  as mentioned in the link , it will impact the report Windchill provides OOTB. Do you know if I can use Jasper Studio to modify the Report Output ( displaying data in tables ) ? If Yes , how can I link it to the infoEngine task ? How do I create one  ?
Is there any documentation/link/samples do you have which can help me understand how to create a Jasper report with steps. I tried to go through the PTC link below , I could not proceed much.
https://support.ptc.com/help/wnc/r12.1.0.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_BusLogicCust_ReportGeneration_JasperCustomization_Introduction.html#
Marco
Thanks . I will go through the links.
