Version: Windchill 13.0
Use Case: Is Hanging change link same as Change Version Link ( redline ) ? If no , how is it different than redline ?
Description:
Need Information.
This is part of the A&D module: https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FChgMgmtUnincorporatedChangesAbout.html%23
Also known as an unincorporated change. Some companies operate this way but we do not. Basically, it allows you to document a change and go all the way to approving the change but not incorporating it. Sidebar: Is this a practice from a bygone error when changes were done on paper by erasing vellum drawings which took a long time? The feature allows incorporation of changes at a later date and version so they are "hanging" until then. A redline could be part of it but is not the same. It is just a markup or BOM redline show what the changes are. These might be part of that hanging change.
Hi @AK_10131364
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
