What are severe entries.?
Hi Deepesh,
Are you getting severe entries in any particular queue? Can you provide more information. Usually the queue entry details shall provide you more information on the error.
Bhushan
Hi Bhushan,
actually I am new to Windchill and I have seen these kind of entries in Propagation queues more often.
I want a basic idea I mean what are these entries and why they occur .
Deepesh
Hi Deepesh,
There are multiple reasons why you would see a severe entry in propagation queue, for instance if an object on which a particular workflow process is initiated gets deleted , you will see a severe entry in the wfpropagation queue.
You can execute the QueueAnalyzer report to check the error in the entries, following article should help you:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS30478
Also, there are some additional trouble shooting techniques for workflow related issue, if that helps.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS232295
Bhushan
Hi Bhushan,
Thanks for your answer its really helpful.
Regards
Deepesh
