What is the use of AvailableAttributes.xml file?
TDT
Fadel
23-Emerald I
(To:TDT)
it is not always the case OOTB, and  for sure custom modeled attributes need to be added Manually https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_UICust_PresentInfoUI_AddCustomModelAtt.html
Generally if we notice that an attribute is not available while creating/editing a a table view , we should look into that file .
PS other modules may have their own file i.e. MPMLink related table views setting is done in MPMLink-AvailableAttributes.xml
Fede
Fadel
23-Emerald I
(To:TDT)
in that file you can define any additional attributes that need to be exposed to table views for a given type
https://www.ptc.com/en/support/article/CS194744 ,for example
Fede
TDT
(To:Fadel)
Hi @Fadel,
But by default all the attributes will be available right?
Fadel
23-Emerald I
(To:TDT)
Fede
TDT
(To:Fadel)
Thank You @Fadel
