Windchill Dev Environment with Eclipse
Hari_Vara
Version: Windchill 12.0
Use Case: Iam trying to set up windchill Dev environment in eclipse.
Description:
As per Windchill customizers guide, when I follow the instructions after the File Sync set up.,
The Windchill Shell input is like this.,
D:/windhcill/windchill/bin/ant -f tools.xml eclipse_project
I had seen the help before and executing the step "Run the eclipse_project task", which is above.
The problem I face is :
Instead of creating the "eclipse" folder in D:/windchill/
the script has created in D:/
It has created the folder D;/eclipse/cust_windchill_src
My question:
Before proceeding , I wanted to check if this is an issue.
Awaiting your valuable guidance.
Best Regards
Hari
HelesicPetr
(To:Hari_Vara)
Hi @Hari_Vara
If you define the eclipse in dev environment and on the server where the Windchill is run, then it is not any issue.
It is just folder structure in that place for eclipse projects.
PetrH
HelesicPetr
(To:Hari_Vara)
Hi @Hari_Vara
PetrH
Thank you Petr!
